Manufacturers say 3months but they are trying to sell the stuff. It varies quite a bit on humidity but I would say you are on the limit given a relatively small nick isn't sealing.How often are you supposed to inject more sealant? I've had the bike since August 2020
And to add from my experience, the sealant will dry up if you do have a very slow puncture or the tyre has never sealed right in the first place ! Been there got the t shirt !Manufacturers say 3months but they are trying to sell the stuff. It varies quite a bit on humidity but I would say you are on the limit given a relatively small nick isn't sealing.
That’s a fair comment again my experience is that even tubeless setup is not infallible but at least there is a good chance your puncture may seal and get you home even if pressures are very low. Where as a conventional setup will often mean stopping and swapping tubes. Nae fun in winter !The argument is not that plugs can hold 50 psi, 100 psi or 120 psi. Or proper sealant, proper seal, rim tape, proper valve setup, or right pump for that burst etc. Or the sealant crystal size is not right for road. The issue is it worth the effort and time.
It make senses if the terrain that you ride in sees frequent punctures as in MTBs. So if you are on decent roads with little history of puncture just work with decent tube tyres with puncture protection material. I think we have taken for granted that the conventional tube tyres have to be breached twice - tyre and tube unlike tubeless.
Not sure if we are looking for a solution without a problem at hand.
You made similar comments in the other current tubeless thread. It seems you feel setting up tubeless tyres takes a long time and I'm struggling to see why it's any more so than tubes?The argument is not that plugs can hold 50 psi, 100 psi or 120 psi. Or proper sealant, proper seal, rim tape, proper valve setup, or right pump for that burst etc. Or the sealant crystal size is not right for road. The issue is it worth the effort and time.
I have to agree , once setup properly. It should work as it should. Large holes will never seal and that’s where the plugs come in. Small holes will seal, you may have to stop and rotate the tyre to the bottom to allow maximum sealant to fill the hole. Or put a finger over it. Some will seal as you ride with a bit of pressure loss. I struggled at the beginning but little did I know that the plank of wheel builder never used tubeless tape !!!You made similar comments in the other current tubeless thread. It seems you feel setting up tubeless tyres takes a long time and I'm struggling to see why it's any more so than tubes?
With a tube one still needs to chose decent tubes, quality rim tape, fit the tube correctly, replace the tyre etc. I agree refitting a tubeless tyre, especially at the roadside, is more difficult than tubed but that would be the only issue.
Roadside puncture repair with a plug is far simpler and faster than fitting a tube to tubed tyre. Add to this incidents which are punctures on tubed tyres are largely eliminated with tubeless and one has far less hassle to contend with.
I'm certainly a convert to tubeless but far from an evangelist. My experience is well set up tubed and tubeless are both hassle free. For me tubeless win because the ride is better, punctures fewer and roadside repair simpler.
Could be it was in not tight enough. However plugs are supposed to put you on until you get home. When home you can do a proper patch up on the inside. I’ve never had a hole big enough to worm in many years of Tubeless.
I'm not at all sure what a "worm" or "anchovy" plug is. I can comment the plugs which come with a Dynaplug kit work with pressures up to 70psi. I'm riding tyres plugged with this kit ranging in pressure from 45-70psi. My oldest plug was put in last February.
I agree there are always new techniques to learn but inserting a plug with Dynaplug is very simple. Find the hole, carefully position the plug and push it in. Nothing more is required.
The OP's puncture looks more like a snakebite where the wheel rim has pinched the tyre.
Yes, but you need to check the other side remembering snakes have two fangs...Can I dynaplug this still ?
Tighten the core slightly with a core valve tool and it won't happen. Its a real pain when you buy tubes with removable cores but forget to 👎I also hate my mini pump as it screws to the valve and ends up unsrewing the whole thing, resulting in total deflation and sealant everywhere!!![]()
Yep, been there, done that. You can tighten with a valve core tool which I usually forget to do!! The alternative is to get some Schwalbe valves with cores that are tightened from the base.I also hate my mini pump as it screws to the valve and ends up unsrewing the whole thing, resulting in total deflation and sealant everywhere!!![]()
