Radchenister
- Avon
Is it right on the sea front![]()
I think it's on a lake somewhere in the Chew Valley BA?
You might just need to adjust the front stop screwdamn scary stuff Typhon... i just bought my bike 2 weeks ago and i realise the gears are kinda grouchy too, and when im riding on top gear, its kinda noisy .. i think the chain is rubbing on the front derailleur..
I never knew Michael Stipe was a cycle mech. Maybe things are a little tight since REM packed it in.
You've not put it back on right. The little lip just inside the cone end of the gaitor should go under and just expose the locknut. The gaitor should then make a seal at the bearing end.Hello All,
I have a Triban 3 and have been lurking around this thread since I found it.
I've checked my hubs for grease which there seem there is plenty present. Since I've put it all back together again I dont think the rubber gaitor that encloses the hub fits as close as it used to. Does this look like it's set too far out?
Any closer and there's a lot of friction.
Any help would be really appreciated. Thanks.
