Deleted member 20519
Just weighed it with more accurate scales and it's coming in at 9.094kg!
That means you have knocked off a kilo in weight,with the wheel upgrade?
Weigh the old wheels when you have a moment
Went for a ride yesterday and pleased to say that the creaking has stopped, fitted the road racer 2 mud guards before ride, back ones fine but the front does tend to rub no matter how I adjust it. So the jury's out on those. Do keep me dry though.
Yeah that's where mines rubbing. So as you say might try it without.I find the front CrudRR mudguard's final section is a bit of a problem - the end piece forward of the brake caliper. This was the bit that rubbed or moved for me. One thing to try though is making sure the cable tie around the brake is not too tight, allowing the mudguard to 'float'... I've got a stock of small cable ties which is always handy. Managed to stop it rubbing - though it still moved when applying the brake. You could just leave this small section of IMO, as I can't see it does much... I think as a design issue the front mudguard stays could be further out from the wheel as my spoke magnet has minimal clearance.
once you get out on it you will love it! look forward to seeing you around the roads of devon soon![]()
Gave myself the afternoon off and did my first 25 miler. I love the bike - a huge improvement on the Hybrid although there is a lot of quality in the Giant. The one big irritation is the constant buzzing noise from from the little plastic windows on the shifters. I could always use a bit of clear tape to hold them down or maybe squirt a dab of superglue into the gaps. Has anyone else had this problem? I was thinking of upgrading the bike but changing the shifters was not a priority and they don't come cheap.
would just spend readies on essentials like cage and bottle / pimp etcCan a newbie please pick the brains of some of you T3 owners?
If you were getting a new T3, would upgrades would you recommend from the products that Decathlon stock?
I'm going down to the Surrey Quays store on Sunday to hopefully pick up a T3 but I've seen a few comments now about changing a few of the standard parts for something better.
I've not got great mechanical knowledge, actually make that noneso at the moment wouldn't feel confident changing things like wheels, pedals and tyres on my own. What I was thinking was if there are upgrades that Decathlon stock that I could ask them to fit when I actually buy my bike. Hopefully saving me some headaches in the long run.
Or alternatively would you not recommend that approach and say do upgrades through a decent LBS?
