Trailers & 'BWSOW's
This is cool!!
https://www.autoevolution.com/news/...ling-a-camper-built-from-scratch-202481.html#
So is this!
Wrong!!
Jameshow
I came across this image whilst looking for something else
I know older (small) 'vans are light, but a Chevette can't have much of a towing limit??
The Chevette's fairly aerodynamic, but that's a bluff front to drag through the air!!
My first car was a Chevette, but a hatchback
Van doesn't weigh much, prob less than 750kg.
I once towed a 1300kg van with a ford focus TDI. That was fun over the Avon mouth bridge!
Finally, after 'borrowing' the 7-core cable from my lighting-board, to rewire the trailer. I sorted the 'L-B' out this afternoon
I called in at Indespension, in Hunslet (Leeds) to see how much it was per metre (Wandahome, at FerryBridge, wanted £3.50/metre!)
6 metres, cost me £9.50 (inc VAT), which was actually cheaper than it's listed on the website!!
At the counter; £1.32
website states; £1.71
Both are '+VAT'
It's far better quality, than wnat I took off it, for the trailer too!
That said, the last time I used it was when I checked whether it worked, & took it with me, when I actually bought the trailer :whistle:
Doubtless, it'll now be another few years before I actually need it!
Is the drivers voice the same as the Coastguard public information film, with the “Look Petunia, he’s waving at us!!”
Caravan safety film (1970s?)
View: https://youtu.be/yqvYFF2QXEY?feature=shared
Friday 14th
This was its first outing since last year!
I had to pick up a (boxed) item of garden furniture for my parents, from a local garden-centre
My wife had told me it'd go in with the seats folded down
However, the trailer probably need a run out, to check for any new rattles/bearings/that the lights are all okay
I'm glad I took it, as it was damned heavy & awkward to hold, so it was far easier to drop the tail-gate, & slide it in!
I'd momentarily stopped on Kirkthorpe Lane, just to the south-west of the blue circle
https://www.geograph.org.uk/photo/7283818
Forgot!
Whilst hitching up the trailer yesterday, with the 'Fathers Day' bench in it, I noticed that its tyres seemed to deform a bit, as I pulled it over to the kerbstones to drop it onto the ball
I pulled the mini-compressor out of the boot & had a check
One tyre was at 12PSI, the other at 8PSI.............
I'll admit, I've never checked them, as it's probably only had 10 - 12 stone of weight in it before
I'm not certain what the pressures should be for a 5.00 x 10, with a max weight of 500KG, but I settled for 36PSI
Jameshow
Forgot!
It's not going to have 500kg in it more like 100kg bench at 25kg and 75kg trailer?
So 36kg will be fine had you put 1/2tonne of gravel you would want 50+psi!
I’ll be watching for sidewall deflection now
Most previous uses have seen me watching the vehicle behind instead, as l haul it up the kerb
I know the bench won't weigh so much, I was thinking if it was loaded to maximum mass
