Tea?
Bobby Mhor
Behind You
Do spoons do porridge?
On the bottle and sleeping...
And that mashing the playdoh is the important bit, for her.
No rain here, warming slightly again as the night progresses.
Anything else that needs doing?
Probably..
I only like my own (and Mrs M's)..
It's one of those things you have to do yourself(ves)..
Toodles is on her way..
hopefully over what she had...
Chaos no doubt will ensue..
Better go hide my biscuits(and stollen)
classic33
Leg End Member
Probably..
You've not asked!
Not becoming a fussy eater are we?
And it has to be a particular brand as well...
She'll have something extra to take her mind of things now.
You don't want it.
Nah, she'll be overwhelmed with what you made her, she'll not know what to do.
Always the best plan.
Bobby Mhor
Behind You
Owdo up there...
None here either from what I can see.
You brought the frost i out of the cold last night, that were nice o'you.
I'll stay warm enough...
You've not asked!
You don't want it.
F-in-L got ours from a mill in Fife that no one remembers what one, plain white bag.
Supermarket ones have been the source since..
BUT they change suppliers at the drop of a hat..
using a brand out of a German supermarket just now...
I could eat them all day..see what I did there?
Hard to believe some are bland, I like a bit of creaminess..
Had a wee failure at the end of one print, creator had put 'rafts' and they didn't seem to print so spaghetti'ed at the very end but a bit of sandpaper, all is well.
Tried resizing one but after an inch it turned to spaghetti as rafts removed for file..
Just did a big benchy to test all was well and a pink one joins the collection.
Must be near time to change the nozzle.
Late lunch as someone is napping..
classic33
Leg End Member
How big a bag?
Same supermarket/brand I bet.
They have to cut their overheads as much as possible.
By chance, does this name start with an a or l...
You'd not repeat it the next day though.
I've been told those that claim to be organic are the worst ones to buy/best avoided.
Will she notice where you put the sandpaper to it. Will she care!
This highly technical term "spaghetti'ed", what doe it look like. Strands here there and everywhere, with no filling?
Plain black?
Cost a bit?
And you didn't want disturbing...
Bobby Mhor
Behind You
How big a bag?
Plain black?
Cost a bit?
I'll take a photo next spaghetti job....
It's the fine string of pla which was supposed to be layered down to make the object sso with no where to go it becomes a jumble ot strand...
All day, it is in the clue...not a little clue.
It's been a merry-go-round getting decent oats..
I may have to resort to Bixies......somebody repro abix, maltier.
I'm wary of organic, label it and charge more for the word...
Nah, all rough edges are smooth so can roll it to her content.
That's enough to be going on with..
This thing I've been asked to do?
It's bleeding massive, almost 800 grams worth.
It's to be downsized I think....
I offered colour before seeing the file and luckily I have a full spool of white, I'll give it a go but it'll take hours and is a possible spag bog.
waiting to happen TBH...
Little miss came up stairs and wanted to play with my four cats, we have three but the gold one is missing...
First Wed in the month, radio comp is finished for 2024..(21.00)
I'm sitting in 13th place....
classic33
Leg End Member
Sounds a right mess, as well as a waste of plastic and time.
All day hunting for decent oats! They that hard find up there.
Sounds like an unsatisfactory solution to your problem.
"Organic" on any foodstuff seems to allow the price to be increased and other fancy claims to be made for them.
She enjoyed what you'd made her so far?
Nearly a full roll required? Hope you'll be charging for yer time.
How far can you downsize and get away with.
White cheaper than a coloured one, by how much. Half, a fifth...
Can it fit on/in your printer, in the one go.
Hope it doesn't get spaghettified on you.
The gold cats not got up and walked out on you.
Any chance you could move up before the results are released.
I know the time & date has passed, but...
Bobby Mhor
Behind You
These things happen..
Once someone changes their supplier, the hunt is on..
normally doesn't take that long..
Yeah, granny bought tubs of playdoh so has her own 'tools' to use on it..
I have done 150% on one off the embossed rollers for Toodles..
Benchy was 125%
Pressing the 'scale' button, pop-up with the 3 axis, and it lets you adjust the 3 together or you can just adjust EG the height, it most likely would be out of proportion though if you do one....
File has just been delivered to my inbox..
While I remember, got this spam/phishing email today..
Check the email contact...
Cost? half a Kg..
£7.50 if white, that's the cost of PLA, normally the white I use is 17-18 quid a KG but I got this one cheaper...
Later in the day I think..
It will take a fair amount of time...
might delay it to Friday early...
dunno what it is supposed to be but looks stoopid...
I know, I'm not last on the evening.....
classic33
Leg End Member
Benchy was 125%
Cost? half a Kg..
They happen, but then you get used to something cheaper in quality. Forgetting what the previous ones were like.
And there's bad weather on the way, minus four forecast for these parts, if the earlier alert is to be believed. The worst time to run out...
That stuff doesn't come cheap, nor the pieces they make for playing with it. And I'm assuming granny isn't playing with either.
All three axis adjusted at a touch of a few buttons?
Wait while later in the day to start it.
Could be genuine, in which case have they put too much thought into it.
Not that cheap, given the size required. If they're paying, don't say you got it cheaper.
Delay until daylight at least, just don't sleep nodding donkey fashion on it.
Not being last is good, it means you beat others.
Bobby Mhor
Behind You
Print job abandoned..
meant for a filament I haven't any experience of,
I'm using the basic jack of all trades PLA,
had seen bed and print head temperature and knew it wasn't right..
Job wasn't sticking dur to the high bed temperature.
Job's a bogey..
Out shopping with Mrs M then a wee long way trip..
new garden centre bagged:laugh:
If resizing , you get the option of the three adjusting at the same time, handy.
There is an option to do just one at a time.
It's amazing at how the whole thing works at such fine tolerances....
I can even pause the print...
I spotted a station on VHF from outside Leeds last night,
I have 'worked' him in the past due to plane scatter,
another SE of Brum as well.
Only jockland for me.
