classic33
Leg End Member
Think you mentioned before you weren't power hungry.Not a power junkie...
I'm allowed 400 watts
I'm in low tens, very low..
Surprising how even 500mW can get you, there is a mode called WSPR
which I occasionally do but not as much now, I'll go down to 500mW although 5W is normal but due to my awfy inefficient antenna, 5w doesn't go out the wire, it is more like 3 at a push..
I originally built the antenna to go out portable, it's commonly known as a 'Rybakov', 9m fishing pole (fibreglass), I hadn't done anything for HF when I first moved in and thought this'll do just now (less the pole and it's still there..
I'm being summoned..
With more power comes the need to pay "them" more to use it. Forgot about power restrictions.
The other side of the world! Ever had anything from out of this world, there's enough up there to listen to.
Could you have managed carrying it all if it were fully portable in use.
Plead "Not Guilty".
first...
