GrumpyGregry
Here for rides.
oh far cough.33 degrees here at it's peak,gutted I tell though and sunny.![]()
Sure Graham - easier to show you on a map. Where do you commute from & what time?
This is my default route at the moment whilst the Metrolink is being put on Mauldeth Rd-normally I would go up Mauldeth Rd, then up Withington Rd or Alexandra Rd South.
The key to the route is to go through Sale Water Park and pass Jackson's boat pub as this gets you into Chorlton. From there you have a multitude of routes to take. The path to Hardy Lane is fine for road bikes too.
On the route I have posted, instead of heading to the big roundabout just outside Deansgate on the A56, there's a shared use pedestrian bridge that takes you over the Mancunian way.
[edit-just noticed that the route turns right in Chorlton on Wilbraham Rd and left onto Withington Rd. I wouldn't normally take that way, but just continue on Manchester Rd, then take the right fork onto Upper Chorlton Rd).
Thanks very much for this - Will try it out, should make a change from coming straight in on the A56.
I probably don't qualify as a commuter - I come in from Tarporley in mid-cheshire about twice a week if the weather looks OK. Anything more would be a bit too punishing! Usually hit Altrincham about 8am. I see your route finishes just about outside our offices in Barbirolli Square.
Could I ask how you normally avoid the A56? I come in on it, but it would be nice to find a quieter route. I've managed to miss out Bowden roundabout and a bit of Altrincham by going through Dunham.
oh far cough.![]()
I'm from Lymm, there should be an alternate route the same way I go in, I only get on to the A56 at Stretford. Big roads you could take the A49 to Stretton, turn at Grappenhall and take the A56 to Lymm. Small roads across to High Legh through Wincham and Northwich.
Cheers, might try a few different routes. Currently go up through Northwich, then Wincham to High Legh - Quite like that bit! Might try going through Partington and around through Flixton one day. Can't say I fancy the A49 on a dark morning - i use it when I drive and its a pretty fast road with lorries. Have seen a few people cycling on it though - Braver than me. Although they tend to be well lit up - I see one guy sometimes with reflectors everywhere - spokes etc. And three rear lights. And a massive front light as well. And a hi-viz jacket.
