SatNavSaysStraightOn
Changed hemispheres!
- ɐᴉlɐɹʇsn∀ 'ɐɹɹǝquɐƆ
there was me thinking ...Tea m'dear.. tea![]()
wait for it....
hot chocolate - tis cold enough outside today...
In fine bone china of course..... with pinkies out!![]()
WussNo ride. Off work in bed dosed up on cocodamol. Playing havoc with my mileage targets.
Thanks for that. These are the lights that I seemed to trigger by riding in primary: https://maps.google.co.uk/maps?q=rh...=Q1QXH9HYgc-UVf5WQblGOw&cbp=12,49.54,,0,14.89I dont know about Welsh Councils but English Councils are Dutybound to reply. I think they can ignore it only if its been through a particular process to identify it as SPAM but even the most spurious of questions get responded to.
The flashing light thing really is a myth, especially if its in ground loop detectors. Have a look a closer look at the site is there is epoxy rectangle in the ground something like this or this. In the first example there's a series of detectors and passing over them all at the correct speed nearly always triggers the lights even though its minor side road. In the second example drivers flash their lights all the time to no avail, it really craics me up
the slip is dominated by the main A90 and also is a bus gate they just have to be patient (I nip through the bus gate
Occasionally you get both types if there's a particular problem but more often if there's two one is redundant and getting replaced by the other.
If there's a box on top of the signals itself then it is a microvave detectors, approach is the key in this case (correct speed/ timing it right) but there can be problems with these types of detector; the below TAL leaflet sums it up.
http://www.ukroads.org/webfiles/tal16-99.pdf
That is precisely what happened with my left hook earlier - he even ended up sitting at a red light long enough for me to use all the swear words I know and a few I didn't realise I knew.Nothing to report other than the usual 'must overtake cyclist' automians, its important they get to that queue 2 secs faster![]()
TypicalThat is precisely what happened with my left hook earlier - he even ended up sitting at a red light long enough for me to use all the swear words I know and a few I didn't realise I knew.
You twit!When I got to work I realised the base layer top I was wearing was not only inside out.. it was back to front...
Return was just as fast & into a headwind, though this time I was trying. My body position is obviously different to my Giro as my glutes really ache today.First proper outing on my M5 CroMo low racer & just over 30 miles door to door time 1h 16m 9s (1h 11m 27s rolling)... but I wasn't really trying
. I did get a soaked neck & head though
