It depends on what you're including in the "ratio" definition - restricting it to just the mechanical parts of the bike or the whole rider / bike system. The latter is ultimately the one that really matters, although as posted previously the range of crank length typically available is that little that it has minimal effect on effective gearing.I don't disagree with that; what I disagree with is the statement that it changes the ratio. Out of interest, do you have a selection of bikes with different-length cracks?
I currently have bikes with 165, 170 and 172.5mm cranks; while one of those with 170mm cranks came to me with 175mm... I'd like to replace the longest for unrelated reasons and if I ever find something suitable the default will be 170mm, although I'll consider shorter if necessary (availability etc).
It does change the required effort; that's precisely the point.It does not change the ratio, it may or may not change the effort required, a 52x13 is 108 inches on a 700c wheel I think, changing cranl length makes no difference to that equation.
Consider a worked example with some extreme measurements for the sake of illustration.
Assume the most effort an 80kg rider can put into the pedal is their own body weight; we'll call it 800N of downward force / load for ease. Applying this to a 150mm crank at the point of greatest mechanical advantage (90 degrees past top-dead-centre of the crank stroke) gives a torque at the crank axle of 0.15*800 = 120Nm. Applying the same load to a 200mm crank arm gives a torque of 160Nm.
Based on a chain pitch of half an inch a 50T chainring has an effective circumference of 50*0.5" = 25" or around 635mm. This equates to an effective radius of 635 / (2*PI) = c.100mm.
The torque at the crank axle generated by the crank arm gives a pulling force on the chain of 120/0.1 = 1200N for the 150mm crank and 160/0.1 = 1600N for the 200mm item.
For the sake of ease let's say we have a 25T sprocket selected at the rear, which will have an effective radius of half that of the 50T job on the front; so 50mm. When subject to the pulling force from the chain this will generate a torque around the rear axle of 1200*0.05=60Nm for the 150mm crank, while the 200mm crank will give a rear axle torque of 1600*0.05=80N.
Finally, the rear wheel has an effective radius of 330mm, so for the 60Nm provided to the rear axle from the 150mm crank it generates 60/0.33 = 45N of force at the tyre's contact patch to propel the bike forwards. Conversely for the 200mm crank this force is 80/0.33 = 60N.
Hence, with the same gearing selection and all other things being equal the bike with the longer crank will accelerate around 1.3 times faster, or will be able to climb gradients 1.3 times steeper for the same amount of rider effort; biomechanical effects of the longer crank notwithstanding.
So if you wanted the two bikes to perform in the same manner with the different crank lengths the gear ratios would need to be changed to maintain the same relationship between force input at the pedal and force output at the tyre - which is the only reason bikes are fitted with gears in the first place..
so ultimate speed isn't important to me. What I do want to be able to do though is to overcome the result of decades of not riding by easing the effort needed to maintain my cadence on what are, to all intents and purposes, flat roads.
