presta
Technically, it does alter the gear ratio. As I said above, with shorter cranks your foot travels a shorter distance, and the gear ratio is distance travelled at the output divided by the corresponding distance travelled at the input.Technically, it doesn't alter the gear ratio at all - one revolution of the pedals still produces exactly the same distance travelled.
Brown's just proliferating more unnecessary definitions, all that's needed is:
Chainring teeth x Wheel radius / (Sprocket teeth x Crank length)
This then is the true gear ratio overall, a simple number that includes all the relevant factors, and is dimensionless.
