Mr Haematocrit
msg me on kik for android
- Out of the saddle
you have pm
I did yes. The guys in Canada carried out numerous checks as well including a torque test and said all was good. My latest rides have been UK which hasn't seen any further problems but lost a bit of confidence with the equipment.I've seen Rear Derailleur misalignment, its not common in general.
Have you reset the Rear Derailleur after the impact?
You really need to get a Di2 trained stockist to have a look at it if you think its misaligned as if this is the case the mech needs to be returned to Shimano for repair.
Out of curiosity is it running Dura-Ace cassette and chain? - It can jump on cheap cassettes without the Dura-Ace/Ultegra ramps or cassettes which exceed Shimano's recommendation for the group set (what's the cassette size)
I can have a look at it if your around London or want to bring it to me.
Hoping to avoid battery issues, is a wiring adapter available to allow me to power my Di2 shifters using one of these?
A spare battery would probably be far lighter,& certainly do less damage to your tyre than one of those.Hoping to avoid battery issues, is a wiring adapter available to allow me to power my Di2 shifters using one of these?
So if I run two bottle dynamos, one either side of the rear tyre, I should be ok then? Would I have to wire them in parallel or series to achieve the required voltage?Really interesting idea, as long as its capable of providing 7.4 volts you would be fine IMHO.
Yeah all Dura-Ace but when the chain failed I changed to an alternate as I read that the Shimano chains had a history of failure. The guys in Canada advised me to change back as it would be a lot smoother ride. They actually put an Ultegra chain on. Not sure if there is much difference.
I shall look at trying to find Di2 trained but struggling here in Singapore. There's a possibility I may be in London in November so I might take you up on the offer. Cheers.
Cassette size is 12-25.
