One other quick Q before I get my credit card out - my brakes are Hayes MX4 mechanical disk brakes. They seem to be very adjustable in terms of pull range and brake lever sensitivity - they have an alan key adjuster on the brake that can change the braking from a wide range on the lever or a really tight 'give the lever a light touch and the wheel locks up' level of sensitivity.
From this, might I be safe to assume that any brake lever will do the job? If it's so adjustable, does the exact amount of cable pulled by the lever matter too much as I can compensate for this brake-end to get it right for what I want?
ITM and Tektro aero brake levers seem to go for £15-20. Would I be safe to order a pair of these? They certainly seem to be spot on dimensions wise.
