Reynard
- Cambridgeshire, UK
If you mean the freewheel oscilates slightly when you spin the wheel, 'they all do that' to a greater or lesser degree.As for the current set up you can tell Raleigh 'mackled' it a bit by fitting a full size nut to the axle instead of a half thickness cone locknut as is usual, this is a bodge I've used myself to
1) get a 126mm wide freewheel type wheel to fit nicely in a bike with 130mm spacing.*
2) enable a 7 speed freewheel to fit onto the axle with clearance to the dropout
BTW a 'through axle' is a completely different type of wheel to that fitted to yours, it's basically a long bolt that pushes all the way through the hub and screws into threads in the frame dropout. I suspect that the type you mean is a QR wheel (quick release) that has a long thin skewer through a hollow axle tube that you clamp with a lever instead of nuts.
View: https://youtu.be/4w6uqN_Pips
This should show the difference
* I suspect Raleigh did this as they had a whole shelf full of hubs that they needed to use up and fitting a thicker nut allowed this.
Ah, thanks for that. Must get my terminology right.
Anyways, no, it's not the freewheel that's oscillating. This is with the freewheel removed. When you look at the axle sideways on, the end that goes through the freewheel body wiggles above and below the axis of rotation.
It's not a terribly big wiggle (for the want of a better term) but it *is* there. Which suggests that the axle is bent. And putting two and two together, I wonder if that has something to do with the broken and twisted teeth on the freewheel...
