12boy
- Casper WY USA
Great project....do you know what the frame is made of? V brakes, in my experience are more powerful than sidepulls, candies or calipers. They do require different brake levers. Unless you are going off road, you might consider non-knobby tires. I'd still use a large tire for the cushiness. My mtn bike has 2" tires with only a little tread and works fine on gravel and hard dirt and isn't much more work than my road bikes. Incredibly plush ride, though. Fat tires, run a little lower on air pressure with flexible sidewalls soak up a lot of bumps. As far as the bottom bracket goes, cartridge bottom brackets are not expensive. Were that mine, I would probably ditch the cranks in favor of a 48 chain ring and 13-32 sprockets which would give a range of 88 to 36 gear inches, and a friction shifter for simplicity. And, as said earlier, replace bars, stem and seat post with used Al parts. A pound or so off the bike, though, won't make it as sprightly as good low tread tires. If those decals have been clearcoated they won't be easy to remove. Good luck with this little jewel.
(When I've become a little bit more mechanically competent. And confident.)
