To anyone new to the route, I would like to point out one particular hazard point.
After Box Hill you go through the village and after a mile or 2 will no doubt be picking your speed back up. There is a hairpin bend which I know had a couple of incidents the year I did it (2013) and it is worth burning into your brain so you take the proper precaution and speed around it, rather than woooshing round the corner and making new friends with the spectators...
Locations
Far Approach
Medium Approach
Near
Reverse Corner View
Be careful there guys.
I did write a detailed course guide based on my early impressions on the course prior to doing it in 2013. It is slightly out of date both in the course from Leatherhead no longer going to Cobham and up those hills, rather cuts straight to Esher via some easier hills, and also I wouldn't rate the hills as bad as I did at that time.
I guess for real newbies it may offer some help.
https://www.cyclechat.net/threads/ridelondon-guide-and-info.136099/#post-2567147
Yeah, good shout. There's a false flat after you summit Box Hill so you tend to be relieved and start to pick up speed on this stretch.
When you do finally pickup speed after the false flat at the top of Box Hill, be careful if you on the left hand side as it isn't the best bit of tarmac in the world. There is worse though.
Is this where we have agreed to meet up and i give you fresh water and welsh cakes?To anyone new to the route, I would like to point out one particular hazard point.
Locations
Far Approach
Medium Approach
Near
Reverse Corner View
Headley is when you go past the Box Hill look out point then climb to the real summit, going wth, the turn a sharp left at a give way.Is Headley that short ramp beyond the downhill after the turn? Never liked that bit.
