Punkawallah
Not nececelery.
Heretic! Burn them!
Not nececelery.
Why so ? I’ve got Deore 1 x 10 on both the MTB and road-use Hybrid. Way different gearing ranges on each, but simple efficient, fuss-free changes on both none the less.
And I’ve never hankered after any more up or down the range…..or between cogs come to think of it…..on either.
I’m struggling to imagine what I’d gain from anything else ?
I'll try anything if I think itll bring something to the party as regards my own cycling. I'm not going to buy uranium gears or hydraulic pedals just because Geraint Armstrong has one.
Because on the MTB I can accept the large gear spacing and reduced chainline efficiency since my cadence is all over the place due to the terrain and I appreciate the simplicity when urgently needing another gear.
I much prefer the closer spacing of a double or ideally triple on a road bike; plus the cassettes are a lot cheaper too..
Actually I don`t think it matters, resistance is still a waste of time and effort. Oh and hybrid has disks, mtb has V brakes, not bothered as long as they! work
Can I ask why? When I rode tubes my road bike pressure would be +/-100psi. I've been riding the same bike tubeless for four years now. Rear tyre 55psi, front 50. I could probably drop to 50/45 and really should try it some day.I suspect that tubeless can work very well in the low pressure / high volume environment of MTB tyres where it originated, however I think pushing to higher pressures / lower volumes (the worst obviously being road bike tyres) is going to be of questionable value and more trouble than it's worth.
