Water is more dangerous, hic.I think my wife read about that - she takes a "safety first" approach and doesn;t eat any veg at all if she can help it!!!
Apparantly, a dose of Broccoli 100 grams and above helps, 200 grams being optimum.
Spam fritters have no effect on hayfever symptoms, you heard it here first
I've been rubbing them over my nipples. When can I expect the effect to kick in?
Which specific effect are you hoping for???
If you want an actual alternative to tablets then you can get little tubs of beeswax (vaseline does the same job but is heavier)
A bot, that spams...And a spambot is what?
I'll look up mumsnet
That last one will make things worse.I find that - assuming I take the tablets - I don;t suffer much when riding
even when riding through the countryside which must be chock full of pollen and stuff
but when I get home and stop - then shortly after my eyes start itching and stinging like mad
On my wife's advise I srated rinsing my face and eys very thoroughly with warm water when this happens
which works for me
the theory is that the pollen gathers around the eyes etc - but the amount is so great that the body's systems are totally overwhelmed and shoot down
Hence not causing the problems
Then you get home and the onslaught stops so the over reactions start off on full throttle
not sure this has any more evidence behind it that broccoli - sorry organic broccoli - but it works for me which os good enough for me
my wife does have an annpying habit of coming up with weird old wives tales
which turn out to work even through the "science" behind it is dodgy
another example is butter on burns
