PpPete
- Chandler's Ford
I've been on to the CTC's helpline... which is just a front for a firm of solicitors, given them a few details, but I really don't like the thought of long drawn out legal proceedings, especially when the driver has already admitted liability, so I thought I'd write to him along the lines of:
Re: Road Traffic Accident 17:40hrs on B3056 north of Beaulieu for which you admitted liability.
Dear Mr xxxxx
As I suspected, my local bike shop are very busy and unable to check my bike for, or repair any damage for the next few weeks. I have therefore examined it closely myself.
I can see no damage to the frame, apart from some significant new paintwork scratches.
The wheels appear to be round & true.
Handle bars appear to be undamaged, however the brake levers have been knocked out of position which indicates that the handlebars have sustained some impact and should therefore be replaced as a safety precaution.
Rear Derailleur (gear) mechanism is badly scratched.
Right hand pedal crank is badly scratched and contacts front derailleur mechanism on each pedal rotation, so would appear to be bent slightly out of alignment. Unfortunately it is not possible to purchase just the crank, these are only available as a complete crankset. An impact sufficient to bend a crank ( a solid aluminium casting) may also have damaged the bottom bearings so I think it necessary to replace these also.
Listed below the exact parts required, with costs, and showing such discounts as I can obtain through my membership of the CTC (Cyclist’s Touring Club)
Frame Respray (http://www.argoscycles.com/www/renovation-pricelist.htm) £125.00
Lug lining and replacement decals £82.00
Handlebars (Nitto B135) (www.freshtripe.co.uk appears to be only UK retailer) £36.00
Rear Derailleur Shimano Ultegra 6500-GS no longer available – replaced by
RD-6700-GS R.R.P £79.99 available through CTC with discount £70.39
http://www.ctcshop.org.uk/cycling/p...700_10_Speed_Rear_Derailleur_(GS)/5360042811/
Crankset Shimano 105 5500 Hollowtech II no longer available replaced by
5703 model R.R.P £164.99 available through CTC with discount £145.19
http://www.ctcshop.org.uk/cycling/p...703_Hollowtech_II_Triple_Chainset/5360057101/
Shimano 105 5700 Bottom Bracket Cup Set R.R.P. £ 24.99 - CTC Discount £21.99
http://www.ctcshop.org.uk/cycling/p/CTC/22/Shimano_105_5700_Bottom_Bracket_Cup_Set/5360057102/
Total: £480.57
I should tell you that I have contacted the CTC’s accident helpline, but since that is now merely a front for a “Claims Management” firm of solicitors, and I really do not like the litigation culture that seems to be growing in this country, I would be quite happy to deal with this matter privately, and ask them to close the case on receipt of your cheque for the above amount.
Finally may I ask that you consider very carefully when you overtake cyclists in future, and give them at least the recommended two metres clearance, to allow for any sudden manoeuvres they may need to make to avoid potholes.
Any thoughts? Especially on the last paragraph ? I'm sure I've read 2 metres somewhere - but cant remember where?
Dear Mr xxxxx
Total: £480.57
