Deleted member 26715
Yes the flywheel has rubbed on the stator windings which probably killed it but if you are in doubt about the Regulator (Chinese) best off replacing the pair imho.
The Triumph OEM Regulator is not the best either to be fair, I've replaced quite a few over the years (they even had a recall at one point).
These are what I fit now, if money allows, they place less load on the stator and do not heat up in operation (a "normal" regulator sheds excess output from the stator as heat), these only take what is needed from the Stator keeping both under less stress.
They stator on your Sprint is designed to be run in oil.
I personally crimp and seal all the wiring as the connectors are another failure point but if you have all new kit then should be fine.
Post a picture up of your Regulator, I'm positive Triumph are Shindegen, SH plus a code on the top (same as Honda use).
A JMP Stator is around £130, they aren't bad quality to be honest.
Can you send me a link to the ones you use, or at least where you buy them from please.
