You and I have done this too often, sir. We should just write "see my post of xxx and your follow up of 5 mins later and my response of 5 mins after that" then we could all just go for aAh ok, do carry on then![]()
I believe you HIC !You and I have done this too often, sir. We should just write "see my post of xxx and your follow up of 5 mins later and my response of 5 mins after that" then we could all just go for acoffee. No, it is coffee in those glasses, honestly.
I've just said, I personally feel more vulnerable on the road as a cyclist than on the pavement away from cars.
One study in Milton Keynes showed an incident rate (accidents per million miles) of:
Main roads 47
Local roads 149
Cycle paths 319
So the accident rate is twice as high n pavements and cycle facilities than for local roads, and almost 6 times as many as for main roads.
Just as a datapoint: I commuted more than 5000 miles through London since last January, and have been involved in hundreds of (what felt like) near collisions, but only two actuall collisions, both with bikes on the same stretch of CS3 with a separated cycle lane that has cycles passing each other by a few inches.
Those figures seem very plausible.
I'd like to know what they class as an incident/accident? is it actual 'offs' or dog/child ran out and a cyclist swerved a bit?
As before - feeling vulnerable and being vulnerable aretwo different things.
Factually cycle paths and pavements are more dangerous than the road with more accidents and injuries occurring on these facilities.
Main roads 47
Local roads 149
Cycle paths 319
Again your personal perception is perfectly valid for you, but does not bear out on a higher scale
That's fascinating. Don't suppose you've got a link to the study have you?
I sometimes use a shared use path when I'm in a "pootling" mood and don't want to mix it up with the traffic (40 limit dual carriageway).
I definitely feel safer on the path, although I have to be switched on at the junctions with side roads, and obviously when pedestrians are about.
Your right, Iv only said the obvious that they can stop some injuries. So lets put this total and inexcusable thing Iv done right, they can also cause some injuries too. But I do believe very improbable injuries.I see that while upbraiding people for not admitting helmets might help in some circumstances, you are unable to admit yourself that they might cause harm in others. Time to get your pot cleaner out methinks.
Sent from my iPad using Tapatalk HD
Is there anything else you want to jump on that I havnt said yet?
Not really a good example, as its not while cycling. Tell you what , Ill add, with cyclists using it while cycling. Just in case you find an example of a cycling helmet falling from a van, and causing a motorcyclist to swerve and crash into a crowd of people who just happened to have been there at the time, then one of the crowd managing to jump out of the way, unfortunately into the path of an artic, who skillfully swerving to miss them hit an oncoming car. Tsk those bloody cycling helmets can be really bad for you"Improbable"?
http://www.bhsi.org/playgrou.htm
The Medical Journal of Australia has published a report from four doctors there who examined medical records for reports of children strangled by bicycle helmet straps.
They identified three cases of deaths from hanging between 2001 and 2010:
The authors conclude that:
- a 2-year-old boy who was suspended by his helmet strap between a bunk bed and a wall
- a 3-year-old boy who was suspended by his helmet strap when he tried to climb out of a home window
- a 5-year-old boy who was suspended from an overhead clothesline while jumping on a trampoline
These cases show that accidental hanging is still occurring among young children who wear bicycle helmets while engaging in activities other than bicycle riding.
The reference:
Bicycle helmets and accidental asphyxia in childhood
Roger W Byard, Allan Cala, Donald Ritchey and Noel Woodford
Medical Journal of Australia 2011; 194 (1): 49
