Does the peds vs cyclists injuries take into account percentages, assuming that there are a greater amount of peds around than cyclists? Or are there just numbers?
I tried to make the same point about uncontrollable events...I'm willing to bet that there are a fair share of irresponsible peds among the stats as it is.
Now, I believe that I addressed those points with my post yesterday.
It's not opposition to helmets, however it may look, because I reckon many of those who you feel are opposing you do wear helmets. It's trying to break through the illusory protective blanket that people place around cyclists who are wearing helmets.
Think about it, studies from hospital admissions show that cycling and walking are both risky for head injuries. Now, whilst the specifics of the stats can be discussed (is it measured per hour or per mile travelled and does it include old people etc) the point is not that they are exactly the same, or that one is slightly higher than the other, even if the difference is a magnitude of three or four, the point is that they are close enough to be considered broadly similar.
Yet we have this perception that cycling is dangerous and we have a whole industry built up around a perceived need to spend money on a bit of polystyrene to prevent us drinking through a straw when everyone laughs at suggestions that pedestrians should wear anything.
I guess I could phrase that another way. If you could be convinced that walking and cycling were equally as risky, then would that make you look anew at your perception of the risks cyclists face or the risks that walkers face? Would that make you more likely to wear a helmet when walking or less likely to wear a helmet when cycling?
If you could answer the two questions at the end, that would be appreciated, as I don't think that the answer people would assume on you would be flattering.
I've never had a problem as a pedestrian, not even close. I've never felt threatened as a pedestrian by a car. I look both ways when I cross the road and if I'm not crossing the road I stay away from the road. On a bike, I've had close passes from cars, vans, motorbikes, squeezed at pinch points etc and been FAR closer to having a problem. I have only ever been close to adding to the cyclist stat, not a ped stat. I believe that everybody on here would say the same thing, I don't think that's even up for debate, and because of that - being closer to problems as a cyclist than a ped on a regular basis - I seek to protect myself. If you just step away from the stats for a min you'll understand that.
I said this earlier in the thread - I don't reckon my head is much at threat of tripping over a loose cable. I may at worst twist something or fracture an arm or crack a rib but I'm not too likely to land on my head. Pedestrian only risks don't seem to threaten much in the way of head injuries in my experience, and I have never felt like my head is at threat as a ped.
These are complete and perfect illustrations of the dangers of perceptions.
You may think that you have never had a problem, or even come close to a problem, but the danger as a pedestrian is not solely from vehicles. (And, as an aside, the chance of a helmet doing much for a cyclist when in collision with a vehicle is vanishingly small anyway)
Danger could be from slips, trips & falls, from walking into a door that someone opens on you etc. Every footstep you are likely to be just a few mm of uneven pavement from a fall but you don't recognise that as a risk. The risks are there, though, the statistics prove that and, if anything, the fact that you don't see them makes the risk even higher.
How, if you would be so kind, if you could be convinced that walking and cycling were equally as risky, because they are, then would that make you look anew at your perception of the risks cyclists face or the risks that walkers face? Would that make you more likely to wear a helmet when walking or less likely to wear a helmet when cycling?
