If you're going to question the figures of my posts. Perhaps your own should be in order first, after-all it was your terminology I used.
No, what you did, whas misappropriate my overall point of;
- It's safer/easier to ride up hills at a slower speed than it is to ride flat roads at a faster speed, for various reasons.
To suggest that I advocated riding slowly to get fit.
I then redefined my point (which only you seemed to struggle with) to insert a broad example of how a lower speed on more difficult terrain, could replicate higher speed on flat terrain. This made it relatable to you. Or so I would have thought?
If you ask for clarification on something, that's ok. It actually marks you out as more intelligent than splitting up a post and addressing things line by line. Post 67 highlights this better than most. You've separated 2 related things and treated them as 2 different points, when they're not.
One of the worst feelings in life is that point in an argument where you realise that things are not quite as they appeared and you're too proud to kind of admit it so you just keep going.
If there's something you disagree with, fine, but sectionally picking holes in things isn't actually of any benefit to anyone.
So, my only question;
Is it possible to get more fitness gains by climbing a steep hill at a slow speed, than it is on the flat at a higher speed?
More than happy for you to create your own working example.
EDIT ::: The above posted before your lengthy follow up.
As I said, you're reaching for this concept of 'slowly'. Speed is an arbitrary number, which is why, when you failed to grasp the original concept, I inserted an example relating speed and terrain to effort.
