They are a bit of a lottery in terms of quality of batteries and chargers I think, some chargers/adaptors didn't have a fuse so are a bit 'dodgy' to say the least.What do you mean?
Exactly what Potsy said. I keep an eye on mine. Only had one original pack that died, pulled it to bits and put each cell in my Xtar smart charger - showed 2 dead. The 2 working cells are in a couple of Trustfire Torches.
Had a power cable go out in flames on a magicshine charger. It was a pukka UK plug and lead to the charger. Plugged in and flames shot out the plug - the cable had snapped (this was a real UK cable off another product).
Thing is with lipo batteries, there is a lot of 'energy' in them compared to AA's. Lots of AMPS, so any shorts go with a bang.
Does anyone know where to get a replacement charger for the Cree XML-T6? The top plastic pin snapped off of the plug making it unusable.
If you mean the top plastic pin on a regular UK plug - just jam something in the top hole to allow other pins to go in then remove it. Flat head screwdriver works a treat*
*Do it with the power off. Don't blame me if you die.
