winjim
Smash the cistern
In this particular case, I expect so.Probably sense in saying "pump tyres and oil occasionally, but I suspect the seed would have fallen on stony ground in this instance as the guy was way.beyond normal stupidity
Would they buy a new car and expect to never have to check the tyre pressure, oil and water levels?
Unfortunately from experience in the trade I can say that there are plenty of people who do expect exactly that and also don't bother looking at the handbook to understand what all the pretty lights on their dashboard mean.Well done to you for keeping calm and professional when faced by such an arse. Would they buy a new car and expect to never have to check the tyre pressure, oil and water levels? (Sorry for mentioning the 'C' word on a cycling forum!) He is probably now getting a kick out of telling other arses how he put you in your place!
That's just reminded me of the booklet that comes with speedplay pedals, which is obviously for the 'merkin market. About the only thing they didn't warn you about was that the pedals might be a choking hazard if swallowed.at the kitchen shop they didn't explain I should hold the knife I just bought by the handle, rather than the flat bit. Cut myself quite badly. Really irresponsible of them
You'd do better living in the USA. Cars there come with a handbook full of big yellow triangles with warnings like: "WARNING! Driving this vehicle into an object at 60 mph to test the airbags is likely to cause serious injury or death!" or: "WARNING! Ensure pedestrians are clear from in front of this vehicle before engaging gear and driving off. Serious injury can result from an impact!"
Ever read a Campagnolo instruction manual? They are at great pains to remind you that anything you do that's slightly out of spec will result in CERTAIN DEATH. If you believed them you'd never ride a bike, you'd be too terrified.That's just reminded me of the booklet that comes with speedplay pedals, which is obviously for the 'merkin market. About the only thing they didn't warn you about was that the pedals might be a choking hazard if swallowed.
Yes, I like the idea of those too. A Single Speed version would be a very clean and maintainence free way to ride I would imagine.YES. People buy cars now and never check anything. And no harm comes of it generally. This is exactly why they expect the same from a bike. If the OP had not lectured the customer about oiling, but spent 20 minutes adjusting and oiling for him, everyone would have been happy.
Then next year sell him a bike with a toothed rubber belt drive and hub gears.
I've learnt the hard way about maintenance of several components. I don't think you take everything in when you are standing in the shop with your bike in touching distance being talked through gears etc.
So things I learnt the hard way.... Brake blocks make grinding paste (new wheels), disk brakes rotors could be cleaned occasionally (new rotor), chains to be oiled, check your tyres for bits of glass occasionally etc but my LBS usually then explains where I went wrong and I've improved that aspect in future. Yes I could have been told it all at first, but I've learnt lots more along the way as he is usually happy to add in a bit of explanation each time. I'm not technically minded, but each time I've not blamed the LBS or the bike, just my lack of knowledge.
Assuming the buyer was used to driving a modern car which would require nothing more than checking the fuel gauge now and again I would doubt if day to day maintenance had ever entered his head.you're trying to blame the seller for the buyer being a muppet... you're on your own (unless i've missed all the posts supporting you)
Assuming the buyer was used to driving a modern car which would require nothing more than checking the fuel gauge now and again...
Generally, the free first service is the ideal point to go through that, I find, rather than bamboozling people who are more focussed on getting a new shiny thing. You get a feel then for if the bike is used occasionally or daily, in all weathers or on dry sunny days, kept indoors, garaged or tied with a piece of string to the drainpipe, and can advise accordingly.OP, when you sell someone a bike, do you talk to them about the maintenance regime required? Do you tell them what they need to lube, what they may need to adjust, which parts will wear and need replacing, when to bring it back to have a proper mechanic look at it? Because if you don't, how are they supposed to know?
Campag? Wow, they still make that?Ever read a Campagnolo instruction manual? They are at great pains to remind you that anything you do that's slightly out of spec will result in CERTAIN DEATH. If you believed them you'd never ride a bike, you'd be too terrified.
