Home D.I.Y.
Katana
CXRAndy
Lincs
Protoyping my spacer
Decided to add a wave guide tube on version 2
I'm slowly getting my head around Fusion 360 CAD. Google sorts out my questions as to how to do certain things
printing in black for final version
Marchrider
Yep Fusion is one massively steep learning curve, when I first started with it I thought it was the stupidist thing I had ever encountered, a sort of anti-logic where nothing worked in the way I thought it should
But then it clicked and its brilliant
have recently started trying to get my head round the manufacturing utility within Fusion (I have access to a cnc router) and that is even more mental y taxing, and unlike the design for 3d printing, there is little in the way of support on youTube
CXRAndy
Lincs
I'm a complete amateur re Fusion. I've got my first 3D printer last year. Then I started trying to design a bracket. Took me hours of playing on fusion to get there. Each time I use it I learn a little bit more. My problem is I'm not consistent, so I need a bit of re learning
CXRAndy
Lincs
Final piece, spacer bracket for tank sensor. The sensor wasn't working, I guessed the slight angle on the tank was upsetting the reflected signal reception. An angled spacer was needed. I used packers to get the sensor perpendicular in both planes, then measured the gap at the widest point. From there its only a matter of figuring on how to make a wedge shape on a circle/hoop. Eventually figured it out with a little bit of simple angle calc-I actually drew the shape to dimensions and the Fusion told me the necessary angle to rotate the object. Voila
A circular wedge 15mins later printed, works a treat
Marchrider
Fusion and 3D printers give a range of possibilities I could once of never imagined
I have an interesting little project at the moment helping someone create a missing part from an ancient machine he is restoring (or at least the part had broken into 3 or 4 bits and he only has a couple of them
With fusion I can keep 3D printing the part in plastic until I get all the dimensions correct, when I am happy I have it correct I will then be able to make one out of bright steel or (hopefully gun metal) on the mill. Making the metal one will be a days work, 3d printing them, or at least altering some dimensions may just take 5 or 10 minutes (without the fusion and 3d I would not attempt making this)
here's the plastic bit that still does not fit well, another couple of goes might get it right
and when I get it right I can then have the exact dimension to use for the milling
