MontyVeda
- Lancaster... the little city.
The cyclinder on mine is acrylic plastic and has cracked at the tightening bolt hole.
Got a replacementbplunge router from screwfix which is s bit more powerful and accurate.
I like the idea of interchangeable base for trim or plunge as well as table and jig bases.
here's a very simple centering 'jig' that'll take ten minutes to make and about two minutes to fit
you need:
a couple of longish machine screws that fit into the base (M4 in my case)
a couple of small bearings that fit snugly onto the machine screws
a few washers and nuts to use as spacers.
providing the bearings and bit are all in line, the bit will cut dead centre when the bearings are engaged with either side of the workpiece.
using the clamps as end stops, it took me about half an hour to cut 48 little mortices
