Well if it ever turns up, I will ask them tomorrow.
Didn’t realise Taiwan was 5 weeks away..?
Blimey, it could of been delivered twice even if they chose the 'China-to-London freight train' lol
I would imagine it would loose a bit of charge , a phone would.
My bespoke fork has arrived in the uk & should be at the shop on Monday.
They will take some pictures before the fit them & giant want my forks back to investigate the problem.
I've not used the bike since the 26th October and when i last charged the battery to full, I just connected the battery to the bike and it only shows 97%
charge. Should it loose 3% charge over that period of time even when it's not connected to the bike?
As said, the battery will drop a bit of charge over time.
No bad thing, fully charging the battery stresses the cells.
Best to leave the battery part charged if you know it won't be used for a while.
No need to be anal about it, anything between about 20 and 80 percent will do.
If the battery is to be left for months rather than weeks, it's worth giving it a charge for a half an hour or so occasionally.
Thanks for that. Thought i may of got 1 or 2 rides in TBH. I may get one in on Sunday (weather permitting) with a bit of luck.
Hope so.
The other thing said about batteries is 'use it or lose it', so giving your bike a blast for however many miles you can manage will do it good.
Sounds "normal". I just took mine out today after a long pause. I last changed to full on October 23. Was at 96% when I started out today.I've not used the bike since the 26th October and when i last charged the battery to full, I just connected the battery to the bike and it only shows 97%
It would really suck big time if I have to pedal this 45 lbs bike up the last hill (West Alpine or Tunitas Creek).
(I have run out of juice on my eneloop e-cruiser, a 55 lbs bike, on the way home and it was painful to pedal that beast even on flat road - I could not imagine doing it on some 8-9% grade hill)
Thanks, proton666. Sounds like this Road e+ may work for me.
I am thinking about staying on OFF mode on flat land and ECO mode on the ascend (but not sure that ECO mode will be enough on the hill climb given the weight of the bike).
By the way, you can walk the bike around the cement road block on West OLH. The portion of road that is closed is actually clear and ridable (even the heavy machines are now gone).
I assume you got up Kings Mt. on ECO mode?
