Particularly as both of those have the Electroverse discount.I would use ZapMap and try using Ionity and Instavolt superchargers.
Actually it doesn't. I mean - yes, putting them on top of car parks is a good idea but the area in the UK is usually pretty small.Makes sense!
Use them for charging too!
It makes more sense to cut losses to a minimum. Minimize the distance the electric generated has to travel first, then consider secondary placementsActually it doesn't. I mean - yes, putting them on top of car parks is a good idea but the area in the UK is usually pretty small.
Plastering them over agricultural land is called Agrovoltaic farming and studies are showing that it works well for quite a few crops and also for sheep farming.
https://www.weforum.org/agenda/2022/07/agrivoltaic-farming-solar-energy/
https://www.theecoexperts.co.uk/solar-panels/agrivoltaic-farming
Not even for sole use in vehicle charging?Actually it doesn't. I mean - yes, putting them on top of car parks is a good idea but the area in the UK is usually pretty small.
The number of panels on top of a car park isn't likely to provide enough energy on a permanent basis. Solar farms usually feed into the grid for that reason.Not even for sole use in vehicle charging?
Numbers of chargers variable, dependant on the sunlight?
Some of the older ones were built with glass on one side to let the light in.i always wonder about the roofs of big factories/warehouses as wasted potential
Indeed and I think we will start to see more solar windows being produced.Some of the older ones were built with glass on one side to let the light in.
