david k
Hi
- North West
ive read things, ive seen things that suggest it was good exercise yes, but tbh, i already knew. ive done enough training in my time to know what is good exercise
Thus you had data available to you to allow you to make an informed descision.ive read things, ive seen things that suggest it was good exercise yes, but tbh, i already knew. ive done enough training in my time to know what is good exercise
because i enjoy it, its good exercise and it gets me round
If it gets you round, you're still eating too much!
I used to be round, but then I started cycling.
I squash good exercise?if i needed it yes but i didnt, its a no brainer. i dont need evidence to tell me cycling is good exercise
Well available evidence suggests that it is only a game fit people should play.ii would think so yes,
however it isnt just the activity but how it is done
Low intensity squash. Hummm. I guess you are the type of person with instinctual knowledge and has no need to research anything?probably because of its intensity, however you could lower the intensity to suit your fitness level, if your so unfit its dangerous then you need to build up to it with a different activity. Regardless really as your initial question was do i think its good exercise, and the answer is still yes it is
i do not need to have evidence before 'popping' up with belief and views. My beliefs and views are my beliefs and views whether backed up by evidence or not
the fact you cannot trust or even have an opinion without hard evidence is worrying
Here's the problem as I see it.
The majority of people who have decided not to wear a helmet started from the position that helmets must do something. They just must. Then, when they examined the evidence, they found that there was no evidence that cycle helmets reduced head injuries. Furthermore, that cycle helmets may in fact increase injuries. The decision not to wear a helmet is a rational decision based on the available facts.
The majority of people who do wear helmets are not fully informed or aware of the evidence. Like the first group, they assume that helmets must have a protective effect, but have not been made aware of the evidence that shows this not to be the case. This is not an irrational decision, but it is not fully informed.
There is a minority of people who have looked at or been shown the evidence, but nevertheless insist that helmets have a protective effect - usually along the lines of "I crashed, my helmet split. If it wasn't for the helmet my head would have split for sure." These people are holding an irrational faith-based position, and we have had people say as much - something along the lines of "I don't care what the evidence says, I will always believe that helmets are protective, and no matter what evidence I am shown, I will never change my mind"
Now if the first group were not under the constant background threat of prohibition, it wouldn't matter so much. But we have real examples of creeping prohibition:
-training courses (which definitely do have a protective effect) being denied to people who do not wish to wear a helmet
-many sportives and other events now state that a helmet is mandatory
-lobby groups and some politicians proposing legislation to make helmets mandatory
There is no prospect of helmets being banned, none. So the people in groups 2 and 3 will always be free to exercise their choice (whether that choice is informed or not) to wear a helmet, but the people in group 1 are always having to justify their choice, as if they are the irrational ones!
Now if you want to wear a helmet, that's up to you, but you cannot pretend the evidence shows them to be effective, and if you make claims that cannot be backed up, expect to be challenged on it - because these are exactly the same claims that compulsionists use, and they need to be challenged wherever they are made.
no, with the helmet being wider than my face im guessing that will take the impact if i fall
