Well, you managed to "publish" those 4 paragraphs with no supporting evidence at all! - but I suppose you also refrained from actually making any point whatsoever - just giving the impression of doubt.
It is not an "assumption" that drivers need to slow down for tight bends - it is a physical limitation. Perhaps as a physicist you could take the trouble yourself to do the maths to calculate the maximum possible speed that a vehicle can follow a 15m radius bend with only the friction of the tyres to provide the necessary centripetal force - allow say a coefficient of friction of 0.65 for a rolling tyre on tarmac. I did supply a helpful link if you cant remember the basics:
http://www.stevemunden.com/leanangle.html
Are you seriously doubting that lower speeds make for a safer environment? or just making a silly debating point?
Perhaps this might help:
https://www.swov.nl/rapport/Factsheets/UK/FS_Speed.pdf
Now for sightlines. The perpendicular arms mean that drivers nearing the junction will have a better view of circulating traffic than with the standard UK tangential arms. So drivers are more likely to cyclists, thus making the junction safer.
Lane dividers are provided to ensure vehicles keep to the lanes and trucks will need to occupy the whole lane. The lanes won't be wide enough for cyclists to overtake on the wrong side or for left turning trucks to attempt to overtake cyclists - and there won't be cycle lanes to encourage conflicting movements through the junction or traffic lights to generate stationary traffic, so this should greatly reduce the left hook problem.
