Pete Owens
All UK roundabouts are indeed crap - which is why dealing with them by schemes such as this is such a worthwhile exercise.And all roundabouts are crap. FACT.
as in traffic lights?It's about position as well as speed- placing turning vehicles at right angles to circulating traffic to minimise the risk of cyclists being in blindspots.
every roundabout I've ever seen in any country, including Holland has been crap. But for reasons you're going to have to work out for yourself.All UK roundabouts are indeed crap - which is why dealing with them by schemes such as this is such a worthwhile exercise.
Conflicts between turning vehicles and cyclists also occur at signalised junctions.as in traffic lights?
1. Drivers: Its bleedin obvious to anyone who has ever driven a car that you need to slow down for bends - and the tighter the bend the more you need to slow down.
2. Dutch Highway Engineers: The empirical research the Dutch did after they converted the first 100 or so roundabouts. The idea was to improve safety by reducing speeds - speeds did reduce resulting in a 70% reduction in crashes - so they rolled it out to convert all 2-lane roundabouts.
3. 'O' level physics - The coefficient of friction of rubber on tarmac limits the speed you can drive round a bend without skidding.
Its not a matter of getting used to it it is a matter of physical limitations.
No. This is a first.
Points 1, 2, 4 are valid - but it is hard to see how any safety scheme in the UK would address this (other than requiring Dutch citizenship as a condition of holding a UK driving licence).
Point 3 is not the case - all the evidence points to cycle tracks increasing the danger at junctions.
And the argument is not just that Dutch roundabouts perform better than UK ones (precisely because they are designed to restrict speeds while ours are intended to maximise them) It is that applying turbo geometry vastly improved the safety of what were already relatively safe roundabouts - they already had all the features you list before they were converted - and already had some of the geometrical features such as perpendicular approaches and exits. If they can reduce crashes on Dutch roundabouts by 70% we can expect an even greater improvement by converting UK ones.
Perhaps when you provide some supporting your opinion.
OK here is a tutorial from a numerate biker explaining how tight bends limit vehicle speed:
http://www.stevemunden.com/leanangle.html
As a physicist, when I publish something, I am obliged to support it with all data, and demonstrate that my conclusions are supported by the data. My work has no safety implications - this does. As such, I don't think it unfair to ask you to provide supporting evidence to the same standards as are required in science publications.
To what degree must the turning radius on a roundabout, junction, or corner/bend, be reduced in order to ensure a motor vehicle must reduce its speed to below 20mph to 'make' the turn? 15mph? 10mph? 5mph?It would help take this discussion forwards if people read the documents on roundabouts and continental geometry that have already been posted. It really is not controversial to assert that people drive more slowly round a corner if the turning radius is reduced.
Most importantly, you have failed to supply the confidence figures for that 70%. Without that, it is entirely impossible to make any assessment as to the validity of that data. (And I also note that you say "crashes", not "cyclist casualties" - does this figure include all traffic? If it does, it is meaningless from the aspect of vulnerable user safety.)
Er no. That's your interpretation. Apart from anything else you are forgetting that the Dutch are adding these to existing roads where the cycle networks already exist and already involve extensive segregation. You are also forgetting that the Dutch approach to roundabout design is quite different from the UK, so you can't assume that applying a turbo design to replace a UK roundabout will be worse for cyclists. Any chance of anyone bothering to read the reports posted earlier?Well seeing as in the Netherlands they specifically route cycling traffic away from these turbo roundabouts, because they are actually quite dangerous for cyclists, so there's your answer.
My problem with a lot of this is the assumption that the lane division will produce predictable behaviours and reduce speeds. If these lanes were, in fact, physically separated this would clearly be the case. But they will be separated only by small plastic 'bumps' apparently, and I (and probably others) have no faith that hurrying, late, or confused motorists won't simply ignore the lanes. In short, believing that this will aid cyclist safety requires believing that motorists will drive considerately, carefully, and in accordance with the rules of this piece of road. Given that according to the AA over half of motorists imagine that bikes sometimes 'come out of nowhere (http://www.cyclingweekly.co.uk/news...groups-welcome-aas-think-bike-campaign-116946) I think relying on their intelligence, courtesy or eyesight may be optimistic.It would help take this discussion forwards if people read the documents on roundabouts and continental geometry that have already been posted. It really is not controversial to assert that people drive more slowly round a corner if the turning radius is reduced.
What of course is needed is a method of changing direction on a bike at busy major and relatively minor 4 or 5 way junctions that does not slow you down much while at the same time not bringing you into any sort of conflict with a vehicle.
It is called a roundabout. Netherlands style, never felt safer. To have priority and respect from motor vehicles is quite something. I don't particularly care if it takes away your "right" to mix it with traffic, cyclists are getting injured and sometimes dying on UK roundabouts, the solution does not include faffing around with compromises and half measures as is this governments wont.
Either go the whole hog or don't bother, everywhere.
The big problem is that in the Netherlands, most motorists are also cyclists, and so the whole culture is different. Cyclists are respected, not treated with contempt as they generally are here in the UK. So it's not a change in infrastructure that's required, but a complete change in attitude. And that's the complicated bit.
Yes absolutely agree, but of course it's a bit chicken and egg. What could well be true though is that if enough infrastructure is provided plus more incentive to ride then numbers ought to increase and a tipping point is reached where the majority of people ride a bike. When this happens then cyclists will have a bigger say in changing the traffic laws.The big problem is that in the Netherlands, most motorists are also cyclists, and so the whole culture is different. Cyclists are respected, not treated with contempt as they generally are here in the UK. So it's not a change in infrastructure that's required, but a complete change in attitude. And that's the complicated bit.
