jefmcg
My father I used "ruler' happily when helping me with my homework, but when making calculations, he used a slide rule, at least until he got his RPN HP calculator.
But arn't languages also about change, though we speak English, its different to that of 200 years ago....because Rule, not ruler is the correct word usage for the measuring implement. A ruler is incorrect English. It's lazy English and has been put into the dictionary as it's widely used, albeit incorrectly. Selfie is also in the dictionary, but it is not a 'real' word. I also have an English teaching qualification.
I
It's not exactly expensive to change earlier though. If we assume that wear is linear and that you can change your chain and cassette as follows:
1. New chain every 2,000 and cassette at 6,000.
2. New chain every 3,000 and cassette at 6,000.
3. New chain every 6,000 and cassette at 6,000.
Anyone got experience on this?
That was my point too. I set it out as if it were linear, then stated that I understood it wasn't so that somebody else could start the ball rolling on real comparisons. Thank you for giving a closer start point.I think the idea is something more like
1. New chain every 2,000 and cassette at 8,000.
3. New chain every 5,000 and cassette at 5,000.
(made up numbers, but you get the idea. the more you change the chain, the longer the cassette should last. Just testing the theory myself)
I totally agree and you have proved my point perfectly.When you start running chains for too long, not only do you have to think about replacing cassettes you also then have to start thinking about wearing out the chain rings prematurely as well. What would the next step be, 9000 miles and replace chain, cassette and chain rings but hope your chain does not snap before then. Its a vicious circle.
How long does it take you to measure 3000 miles with the ruler though ?I measure by a ruler, and usually get about 3,000 miles.
I just changed it, it wasn't worn, well no more than say 1/16th of an inch. I measure the bottom length under tension from the RD and there was little if any to the cassetteIf your chains elongated 3000 miles you certainly got your moneys worth out of it. Where do you take the slack up?
You tart you.I don't measure chains, my bikes get a new chain every 12 months, and my geared bike a new cassette every 3 years, my fixed gets a new cog every couple of years.
I can do up to several thousand miles a year, (though been slacking this year) I usually get through a chain every six months or so.I don't measure chains, my bikes get a new chain every 12 months, and my geared bike a new cassette every 3 years, my fixed gets a new cog every couple of years.
