Some time further without oil, instead a couple times applied that cheap 3 € / kilo viscous aircraft/door hinges grease.
The period after mounting the new Regina Urban OROX type 420 chain, just like the previous time start 2020, there is some muck / some clots - that white grease the chain is delivered with, that is pushed out (partly?).
I smeared these open with a cloth, to spread it over the externals, as addition to my grease.
As now proved after riding enough (too many :P ) through downpours, and unlike last year: NO rust on the chain. Last year brown substance even spilled out between the side plates, indicating internal rust.
At 1st sight rather odd, because the chain appears close to bare metal. But when looking closely: it's covered by a metallic looking grey substance, I guess the mix of both greases, that somewhat covers the gaps between the link parts, maybe blocking dirt / water from getting in.
The chain still runs totally silent (despite the seriously worn, but flipped regularly (hurah for the dead easy M12 bolts that now replace the tiny original chainring bolts with sleeved nuts) so no sharkfins, Velosolo chainring) - something I never experienced before with oil lubrication, there it was just the first couple days, then a couple days hearing blotter, then just rough / noise, as before oil lubrication.
Also remarkable: no dirt on the chain. Apparently, again unlike oil lubrication, dust/sand/whatever, doesn't stick in / stay on the grease.
So, so far it looks promising.
What effect it will have on chain wear, will only be proved the moment the tensioner reached front end, though.
Even if that would be the same, the grease inflicts me much less cleaning work on the chain than the oil.
So far I had to turn/move this eccentric bottom bracket tensioner about 1/3th of the distance I had with the previous chain with oil lubrication, same time, same daily distances.
			@Yellow Saddle was the resident expert but they have closed their account so I can't easily search for a comprehensive answer that they is sure to have given.
Aside and also not my business, asked nevertheless: why account closed?
