Quite telling your use of the phrase "weekend job". By comparison I did an engine swap on my 68 Cortina on my own in the rain, though the rain likely speeded up my work! Granted the Cortina was a very basic car and incredibly easy to work on. I needed a whole weekend to lift or replace the engine in my metro as it was a lot more tricky, though my mini-racing pal could doubtless do it in a couple of hours
I don't rush my jobs, not a mechanic by trade. Kudos for doing engine swaps on the side of the road![]()
I think "dog slow" might be a bit harsh given it likley had the same power as my Cortina back then !
?Quoted at
Quoted at 48hp but that was a crankshaft reading, by the time it had gone through the transmission and shaft drive it was somewhat less which was why they tried bolting on a turbo and then boring it out to 650cc (actually 672cc)
20 is ok if you've something to weld to...or if that's all you've got.Id be tempted tor something a little thicker...16 and you won't blow holes in it !/Hi all,
I/'m patching a seal on a 944, not a big hole it needs doing but it dose not need a whole new seal yet lolol it first welding and its a 1984 not bad. i think it was caused by someone trying to lift it in the wrong place.
now my question is 20 gauge 0.9mm steel or little thicker? just want to make a nice job of it?
Still about 230hp per tonne.
My Cortina had a claimed 60hp
/Hi all,
Isn't it best to use same thickness steel where possible
That's what I've read.
Whilst I did an intro MIG course we only had a play with thin stuff after finishing the course test and I for one found it quit hard
I find it difficult to master. I practice alot on similar thickness until I get a presentable weld and not blow through the metal.
