T.M.H.N.E.T
- Northern Ireland
Which you aren't of course.
If you're going to be arrogant, have something to be arrogant about, getting a top ten finish once or twice in a cat 4 race doesn't cut it.
I'm sure I can, in the very same album. http://www.cyclingnews.com/news/pho...hit-the-gym-ahead-of-team-presentation/248511There's a lot of irony there - and surely you can do better than Albert Timmer?. Incidentally, who's a 4th cat..?
You are overgeared - if you use a low enough gear then strength doesn't come into it! Top pro climber Contador doesn't have massive legs - he uses low gears on the steep stuff.
You have got to do some squats and work that one out for yourself!
4th cat, 3rd cat, pussy cat, same thing
Hmm, yes I see where you're coming from. I prefer your answer to B&Y's![]()
Rob3rt, at the risk of winding you up any further, what is 'MAX YOUR PUMP' ? Sounds like the strap line to an 80's VHS spandex work-out.
So your best argument for weights is that two blokes from Argos Shimano do them (one of whom is a sprinter)...?
No.....
...I'm pointing out that you calling other people's posts nonsense whilst offering no credentials yourself is irritating. Much of the stuff you say is good advice, but you put your point of view across like a nobber. Put your advice forward without feeling the need to belittle others, and please offer your corrections more delicately.
I can call it nonsense because it is. All someone has to do in order to correct me is come up with some proof that what i am saying is bollox. It is up to those claiming that weights make a difference to prove that it does (I'll give you a clue though - there is no published scientific evidence that it does work). The trouble is that the best that most people can come up with is meaningless anecdotes like 'it worked for me' or 'the pros do it' (although most of them don't - so read into that what you will).
Well you can't spell for one - I never trust the advice of people that can't spell (incidentally the same approach is also appropriate for internet dating!)![]()
Incidentally science never "proves" anything, it merely proffers a selection of studies that either support or refute a hypothesis leaving the reader to make their own mind up . . . .![]()
