MacB
- Farnborough, Hampshire
B&Y is correct, despite his atrocious level of communication ability
Terminology and semantics are getting in the way a bit as well and the key is the difference between strength and power output. Strength will tend to vary as a by product of whatver activity and training you choose to do. But, as B&Y so eloquently points out, the inherent strength most of us possess, that enables us to walk/ climb stairs, run, etc...has a maximal effort capacity far in excess of anything you would put into a single turn of the pedals under general cycling conditions.
Perhaps a better example than stair climbing would be lifting weights. I could walk into the garage now and press 100lbs with relative ease. If I wanted to do so 50 times in a row I would need to factor in recovery time. By training I could reduce the amount of recovery time required, any strength improvement would be a by product but it wouldn't be a requirement.
