ayceejay
- Rural Quebec
"Working on strength only will not cut it."
Can't be arsed reading all the crap, but in answer to the OP it is the watts (power) you can sustain at a given cadence. No use being able to spin at 110 rpm if you can only hold 200 watts at that cadence for any given period of time, ie you hit a hill and stall.
So we have
The Tractor, low cadence, massive power,The grinder
The V8 muscle car ~ high power high cadence ~ The good all rounder
The Moped ~ High cadence, low power ~ You
Work on hill repeats and muscle tone to increase your power and then the higher cadence on the hills will come.
So we have
No! Endurance riding is about sustaining a given power output over a given distance. Endurance riding has NOTHING to do with leg strength. Leg strength is not a limiter to endurance riding. Show me some evidence to the contrary.
Ohhhh - once again, you've not grasped it. To push harder, you need to be able to tolerate a higher effort. This does NOT mean 'stronger' legs (incidentally, did you actually look up the dictionary definitions of 'strength' and 'power'? It doesn't sound like you did)- it means training your body to produce more sustainable power. Strength is not a limiter. Sustainable power is.
But some level of leg strength is required to complete an endurance ride.
You've (or the data you've sourced) set the bar, the required leg strength, at the ability to climb a set of stairs. I do not argue that if one is able to climb a set of stairs one could also condition you legs to maintain that 'power' for the duration of an endurance event. the point is, what if you want to improve on the ride time for endurance event.
Stronger legs producing more power to travel faster over an long, endurance, ride. Leg strength will now be greater than required to climb a set of stairs.
Your position that 'stair climbing' strength is sufficient to complete an endurance ride is correct, unless you also include a time objective, i.e. go faster up a climb. At that point I feel leg strength is key to producing the additional power required.
...wrote more stuff...
I've been trying to think why I consider that the claim that 'stair climbing' ability provides all the strength required for cycling as a bogus suggestion. The suggestion is that average power/strength requirements per stair step versus per pedal stroke are greater. And from what I've read this is true, especially considering endurance events. The problem is cycling peak/spike power/strength requirements can far exceed the power/strength requirements to climb a single step. Exceeding even the maximal leg strength of our stair climber.
For me the power and strength range to be a proficient cyclist exceeds (upper and lower limits) those of the stair climber and therefore the cyclist must develop stronger legs than stair climbing can develop alone.
Anecdotally I see this happening in two ways. One, as my daughter develops as I cyclist I can see how she builds stronger legs to overcome the small inclines on our rides. Yes there is some technique development and conditioning also going on, but in her lowest gear there were times she couldn't even turn the pedals. Now she can climb with no problem other than being out of breath at the top.
And two, almost every new cyclist I know has found stairs to be easier after they have begun cycling. Not just in being less out of breath after a flight of stairs due to improved fitness, but also at each step. Showing for me that their cycling has developed additional leg strength above their minimum required to climb each step. Though admittingly probably within their original stair climbing maximal strength.
If you find stairs easy after cycling you didn't work hard enough on the bike beforehand.And two, almost every new cyclist I know has found stairs to be easier after they have begun cycling. Not just in being less out of breath after a flight of stairs due to improved fitness, but also at each step. Showing for me that their cycling has developed additional leg strength above their minimum required to climb each step. Though admittingly probably within their original stair climbing maximal strength.
Of course they can - and they often do. But is the requirement likely to exceed your maximal strength?? NO. Pretty much the only time when you will ever exert anything like a maximal force on the pedals is from a standing start in a high gear, like on the track. Once the bike is underway, it is practically impossible to exert a maximal force on the pedals anyway.
The changes are cardiovascular not strengthNo, see this is where I disagree, the untrained cyclist, whose only demonstrated level of fitness/strength/power is that they can climb a set of stairs, will have attempt to exceed their current maximal strength at some point as they develop as a cyclist.
Failure of your cardiovascular system not lack of strength.And as to practically impossible to exert maximal force when underway, you've obviously never ridden a mountain bike or a single speed up a mountain where it's possible to exert to failure in a single pedal stroke.
This is where I think Stern get's it wrong, I believe he over estimates the potential maximal strength the untrained stair climber is capable of. Why would the body develop a lot more strength than it requires to climb stairs if climbing stairs is the hardest thing a body ever does.
The 'stairs analogy' is just a good, practical, everyday example to illustrate strength that most people (most people apart from you, that is) seem to understand...And as to practically impossible to exert maximal force when underway, you've obviously never ridden a mountain bike or a single speed up a mountain where it's possible to exert to failure in a single pedal stroke.
How many times does this need to be said?
