LegsRsore
- Haydock, St Helens, Merseyside
Good question
so what woud u say is the best approach to climbing ,im more of a grinder and i really struggle to get spinning as high as some people have mentioned here ,when i spin (relative term)i really feel that im getting nowhere ,id say my fitness is pretty rubbish,but im pretty strong in the legs (maybe this is the prob )i squat a bit but seem to run out of puff on the bike .
iv tried to go out and increase my cadence and not use the longer gears ,that lasts for a mile or so when i realise that im getting nowhere about 10 mph and revert to getting out the saddle and horsing (relativly)a bigger gear ,
whats the best approach ,not only on hills but even on the flat ?get the cadence up?
Yes, I saw you write that before and you were wrong then too. Repeating an opinion doesn't magically make it a fact.I'm beginning to lose count of the number of time I've said this, but if the OP can climb stairs or get up out of a chair unaided, then he already has all the leg strength he needs to cycle - as do you or I. The trick is converting that existing strength into a repeated aerobic effort - which comes through training.
Muscles don't tire because they are not strong enough - they tire because they are not used to performing at whatever effort you are requiring them to perform at, or for the length of time you are requiring them to perform for.
The OP may have enough strength to climb some stairs, that doesn't mean he has enough leg strength to travel up hill as fast as he wants.
I'm sure Hoy and the like only build up their leg strength to look good and nothing to do with going faster. And I bet even skinny old Wiggins himself is carrying a lot more muscle mass on his legs than he needs to just climb some stairs.
I'm for doing training that is specifically going to aid cycling performance. The type and nature of events that you are targeting will dictate whether specific strength work done with weights makes sense or not.
For example, I would have some riders focussed on track TT & sprint do weights. Even then the nature of the weights performed and balance with bike training needs to be considered. Many are actually better off not doing weights at and focussing their sprint work on the bike.
Problem is, the physiological adaptations induced by real strength/weights work run counter to those required to improve endurance cycling performance (ECP). e.g.
- it adds mass for no gain in aerobic power output,
- increases diffusion distance for exchange of key metabolites and gases at the cellular level,
- reduces mitochondrial volume (mitochondria are the power production houses inside our muscle cells) and
- does not stimulate capillary growth/density (critical for supplying the working muscles with O2),
i.e. runs counter to all things necessary to improve sustainable power.
There is a low correlation between strength, speed and endurance.
Finally, the pedal/crank forces in ECP are very low (typically nearly an order of magnitude less than our maximal force generation capacity), such that our (maximal) strength* is not a limiter. If you can walk up stairs or get up from your chair, you are strong enough to ride a bike up Alpe d'Huez..
By all means do weights for other reasons but a claim they aid ECP doesn't stack up.
Nevertheless, some exercise is better than none. And any exercise for an untrained person will aid performance. But typically we are talking about people who are already reasonably (cycling) trained to some degree.
For those that can't ride, then anything that engages a large muscle mass in an aerobically meaningful manner is preferred. Walking, jogging, running, stairs, elliptical machine (my pick), rowing machines X-C skiing etc etc
I wish people would stop referring to Chris Hoy and other track sprinters as examples in this context.
That's why I added Wiggins too.
Wrote a lot of bs.
The coach you quoted isn't wrong and even recommends that to build length strength one should do more sprint work on the bike.
And he may be right about endurance riding, but I don't ride endurance events (my longest race this year will be 100 miles) and can therefore carry more muscle mass and I don't have to sacrifice power when I need it.
But to state that stair climbing strength is sufficient is to climb the Alpe d'Huez is an over simplification and wrong.
for anaerobic sprint work in track events - did you miss that bit?
Hello? You DO ride endurance events. Any distance which requires aerobic effort (as opposed to anaerobic) IS an endurance event. A mile-long race is an endurance event. Look it up.
You are either unable to understand what I and others have written - or you are deliberately ignoring it in order to perpetuate your baseless argument that leg strength is an issue in endurance cycling. I'm guessing the former, seeing as you didn't even know what 'endurance' meant. Remember, you are not arguing against me - you are arguing against accepted practice, conventional wisdom and sports science. Why are you even arguing this stuff when you are obviously clueless? The fact that you have the nerve to flippantly dismiss my previous post as 'BS' just shows how ignorant you must be.
The OP was not asking about tips for endurance riding, but some ideas about improving their climbing. And I still suggest improving leg strength will help.
Endurance riding, as you know, is a trade off between mass and leg strength.
And to push harder you need more leg strength.
You're arguing with someone who is always going to be right (in his head only) and has no understanding of anything really.
Just FYI![]()
What this means is that anyone with the strength to climb stairs could ride a bike up Alpe d'Huez, eventually.
