oldfatfool
That wasn't my point, if you pedal faster in the same gear you are doing more work, as well as being exasperating you can't bloody read!!No, but it is an example of doing more work to produce more power rather than doing the same work but quicker.
I was countering to your point that there's no need to do more work, just pedal faster. Increasing cadence is only useful up to a certain point, after which more work needs to be done and potentially, as in climbing a hill, more strength is required. This is not rocket science.
Ah well never mind, oh and just to give you an answer to your other post, pulling on the handlebars is because you have run out of fuel nothing to do with strength, try climbing a few hundred stairs and by the top you will be pulling on the bannister.
I am bored now with trying to explain simple Physics to a Texan.Good night
