Ralphbostie
If you do get the mudguards, I bought two small L shaped brackets from Wilko, drilled a small hole in the top of the mudguard to take a small bolt, fitted the L shape bracket to the plastic guard and bolted it into the hole in the fork to secure them better, same with the rear. These mudguards were recommended by Boardman when I emailed them, i got mine from Tredz, they give you a discount if you join their newsletter.Yes I will make sure they are done with loctite And torqued up properly.
I just bought the down tube cover as well, got it for £70, thanks for the tip on mudguards as I have been looking for some, I will check them out. Seems a very good idea to stop as much dirt as possible getting on the vent. thanks again.
Just looked at the mud guards , am going to get some.![]()
