I recently asked Fazua about the clicking problem with my last bike and the cover for the sensor cables underneath.. I know everyone knows what it is but this is what they Said and attached a very good video :-
Thanks for using a Fazua system.
The noise may be caused by the incorrect tightening of the bottom bracket screws.
I recommend that you (or your local bicycle retailer) check all the fasteners as indicated in the following video and the attached document :
View: https://youtu.be/t5rO2_7FPYk
I would start from the 4 screws that hold the bottom bracket to the bike frame.
Regarding the cover: The bottom bracket is supplied from us to manufacturers without any cover (as in your case). It is then a manufacturer's choice whether to apply protection or not. Some add it and others do not. You should ask Boardman if they offer it.
Regards, | |
reply from Boardman
Thanks= for getting in touch.
All of the junctions and wires are weather proofed which is why there is no = need for a cover.This is not something we would be able to supply you with = if you wish to have it covered.
Now we know !
