Really?!
As has been said before, you are very upright!The problem is that I can't get off the hoods. I seem to have a lot of weight on the little finger/ring finger part of my palms and an ache in my lower neck and between my shoulders. It's like my hands are glued to the hoods. While I can lift my fingers and thumbs off the hoods, I don't seem to be able to move my hands without becoming unstable.
I'm trying to figure out what is a lack of core strength, what is bad fit and what is me overthinking things.
Yes. Why? Enquiring minds would like to know...@Aluminium Falcon - just a thought - you are measuring your inside leg from floor to crotch in stockinged feet. aren't you?
Don’t be shy @ColinJ , admit your practicing your Les Dawson impression .View attachment 670819
(Please forgive the pout - I have no idea why that was on my face when the photo was taken!)
Yes, really. My knees are stuffed and rather sensitive to an over low saddle
Yes. Why? Enquiring minds would like to know...![]()
- because if, for example, you were using your trouser inside leg measurement for any saddle height calculations, you would end up being way out.
Well that is the same measurement you are supposed to use for determining your trouser inside leg measurement. It isn't the same as the actual seam length of the trousers.
Just done the "book-to-wall" method to measure my inseam and with the book a "snug fit", I got a measurement of 75.7cm which calculates to a saddle height of 66.843cm rounding up to 67cm and then subtracting 2cm so that I don't have to worry about finding the centre of the BB gives me a seat height of 65cm. Considering that my last calculation was 63cm (with rounding and subtraction) wasn't far off this new figure at only 2cm, or 3/4" in old money, different.
OK, I know, 3/4" is actually 19mm
Will adjust accordingly when I get the chance.
I've heard SWMBO say something like that before......It is surprising how much difference that 2cm actually makes in reality.
Thanks for the response. I don't seem to be able to get off the hoods and into the drops, but that might be a lack of confidence/practice.
Oddly enough, I also prefer a flat bar. But I have an MTB, there are no other bars thereAs has been said before, you are very upright!
You need to ride your bike, ride with your hand on the hoods, forget the drops and ride upright if you like until you get more familiar with your bike.
As you get more practice in, try and bend your elbows and bring your head down, have a look at @cyberknight photo earlier in the thread, that position is spot on.
Some people don’t always get on with drop bar road bikes preferring to ride flat bar hybrids, you may be one of those but you won’t know until you get some miles in. Persevere and good luck👍
