EltonFrog
I started on the front wheel yesterday, as you can see from the photos it was quite rusty and dirty. I used much the same system cleaning and polishing as I did the rear wheel, starting at the valve hole working around the wheel with wire wool, wire brush and white spirit, finishing off with Autosol chrome polish and a clean cotton cloth.
Rusty Front Wheel Hub
Speckled Rust on the Wheel Rim
Rusty Spoke Nipples.
Caked On Dry Grease and Dirt
Rust Spots on the Inside of Rim
Axle and Bearings Out
Claggy Axle
Hub Polished
Rim Polished
Removed Rust Spots
Clean Spindle / Axle
New Grease and Bearings
Shiny Wheel
Before and after photos of front wheel.
The axle and bearing races were degreased with a cloth and white spirit, the ball bearings soaked overnight in a jar of white spirit. There are supposed to be 20 balls, I only had 19, fortunately for me my neighbour who just happened to chatting to while I was out the front of my house working on the wheel told me He had some ball bearings of the 3/16th variety in an old tobacco tin. That saved me buying a load I didn’t need.
After all the cleaning was completed I set about greasing the bearing races and fitting the balls and axle, everything is running nicely. The last photo in the gallery is just the wheel offered up to see how it runs. It’s perfect.
