EltonFrog
Good advice.Rather than load individual loose ball bearings in with tweezers, which I find a bit of a faff, I use a different approach. What I do is fill the bearing cups with as much vehicle wheel bearing grease as I can physically cram in, then load the balls into the cups with my fingers and spread more grease on top of them before fitting to the bike. If the fixed cup won't come out of the frame I still fill the cup with grease the same way but load the balls through the axle hole from underneath. I have an old cloth or bit of blanket under my workmate, so if I drop a ball it will stick to the material and not bounce away and disappear. Searching for AWOL ball bearings during a rebuild is incredibly irritating, and I really don't have the temperament for it!
I’ve come to a pause on this project, I’m waiting for parts.
