EltonFrog
For the record 3.5 hours.Fantastic job there carl, I can imagine how long that took to do,![]()
Hey Carl, as for the hub, if the gears all work after flushing, might be a case of 'if it ain't broke don't fix it'.
Gawd! I am a dumb arse sometimes, shouldn’t be let near a feckin Lego brick let alone bike.
I was pondering the dilemma of the gears late last night when it dawned on me that the problem is probably not the gears but instead the bearings. A quick search on the tube of u and I found an excellent video on how to service the bearings.
I got the wheel out again and set about investigating my theory.
Clamped in the workmate.
Got the ring, cog, cover, washers and nuts off. Also the clutch mech (I think) , spring etc.
Got the ball bearings out using a very powerful magnet (didn’t drop any this time) View attachment 512110
The. I took this clutch thing apart. No wonder it felt notchy.
The bearing cage is fecked. I’ve ordered a couple, in the meantime I Cleaned and grease put back Together what I can. I’ll have to wait now.
Bearings cleaned, new grease and replaced.
Retainer cap replaced.
Just hope the new bearings won’t take too long.
Just giving the wheel a gentle spin in the clamp, and already I can tell that was the problem.
Sometimes the bleeding obvious is staring at you in the face and you don’t see it.
A great little tool is a magnet on the end of a car aerial, brilliant for retrieving loose bearings.
Might just be the photo, but looks like the sprocket has lost one of the 3 'spigots' that engage onto the hub? - can't see that it would contribute to the symptoms you describe however.
nice work!
quick question about Oxalic Acid... does come in powder form to be mixed in a liquid?
Ironic me talking about projects, just seen this abandoned outside M&S in town. The council will end up removing it and selling it for peanuts.
That’d be a great project. Edited to add @Gunk I'd be very tempted to liberate that and give it's freedom, I wouldn't but I would be tempted.
That needs rescuing quicklyIronic me talking about projects, just seen this abandoned outside M&S in town. The council will end up removing it and selling it for peanuts.
