I've dropped out of the CG for the time being to concentrate on Climbing / Endurance riding and Endurance intervals, partly to see if I can drop a couple of kilos before Mallorca, but also to get myself in proper shape for long days and lots of climbing. I did a Bkool route week before last which is Alpe D'Huez, Col de Sarenne, then drop down the back of the Alpe to Bourg d'Oisans .. A mere 34.5 Miles and 5000ft of climbing, in just over the 2 hours ... My planned big ride is 3 times that , I can guarantee that I won't be doing it in 6 hours, and will not be pushing 300W going downhill, in fact I don't think I'll be pushing 300W going up hill either. The one thing that concerns me is gearing I run a 50-34 compact and an 11-32 rear, the bike I'm hiring is 50/34 and 11-28, with no option to change it. I know I have the power to drop the cadence to 70/75 and grind up (although perhaps not for 9 miles of 5-6%!), so I can ride it as long as the knees hold out.
Personally I'm seriously looking at going sub compact with Absolute Black oval rings, why do I care what people think if I'm not running a 53 /39 and 11-25 like the pros? I'm 55 FFS, I'm not a pro, or an elite athlete, I'm doing this for 'fun'. Using the Bike Gear Calculator I get the following on a 25c tyre at a 90 cadence
50 - 11 gives 120.3" top speed 32.2 MPH
50 - 32 gives 41.3" top speed 11.1 MPH
34 - 11 gives 81.8" top speed 21.9 MPH
34 - 32 gives 28.1" top speed 7.53 MPH
48 - 11 gives 115.4" top speed 30.9 MPH
48 - 32 gives 39.7" top speed 10.62 MPH
32 - 11 gives 77" top speed 20.6 MPH
32 - 32 gives 26.5" top speed 7.1 MPH
So nothing drastically different, apart from the ability to turn the pedals, the torque figures are interesting significantly easing strain on the knees.
Aleman, I dont know what you weigh? I can give you some background to gearing of my setup and those I have ridden with up mountains. I weigh 92KG, so hills are not my strong point for speed. I built a touring bike with the capability to climb mountains gradients in comfort. I did my research and opted for mtb groupset. The original gearing was 40/28 crank and 11-32/40 cassettes. It has been perfect for allowing me to spin, I mean 85rpm and above up mountains like Teide or Ventoux. I have now changed the outer crank ring to 44T, because I got dropped in the IOW cyclechat ride going down hill. This extra allows me to go upto 32mph and keep cadence at 100rpm. I tried this modified gearing last month in Tenerife and found the extra top end very useful for low percent descents where I could power along without spinning to high.
Now I've ridden with about 30 different riders on these mountain events and all of them weigh significantly less than me. Most top out around 83KG. All of them used 50/34 crank and 11-32 cassesttes. They were able to ride up the same mountains as me in reasonable comfort, albeit they were on the 34crank and 32t cass- no bailout gear left.
If you plan long mountain climbs and weigh more than 85kg get easier gearing than compact 50/34 11-32. This all depends whether you're are comfortable holding a lower cadence for several hours, I'm not personally, I like >85rpm for long climbs. I hope that helps, not trying to show you how to suck eggs either
