berty bassett
- I'boro
sorry i couldn't help it ! i think i may have a form of tourretesSome of us are just naturally less hairy . We can’t all have legs like we’re Chewbacca and Big Foot’s love child!
Ps
Ps
I will be up for joining the races regularly if they start around 8pm, to allow me to get back from work and finish parental duties
Hardware boys, a question.
Trying to sort miss shifting on rear cassette. It should be other way around but... have a 105 cassette on best set of wheels that misshifts. Thru axle fwiw. Remove wheel and stick in spare wheel with ultegra cassette. Gear shifts etc fine. But, bike on its saddle, when I turn cranks with my hand and then let go the cranks continue to turn under tension albeit slowly. Never seen this before. If I put the other wheel set on and try this then, as you would expect, cranks stop and wheel continues to spin. What’s wrong?
You've broke it
Sounds like free hub is seized. Can you spin the cass in freewheel mode or is it jammed? With wheel out of bike cass should lock drive and spin freely opposite direction clicking in freewheel mode
Did mention worn cass to you, just sounded like it on TOC
Going for TT now comment later
Good speed and power on the TT
I managed to do the danish Gran Fondo TT after all. Really cold, strong winds and a lot of tight turns. Normaly not the conditions for an all time best result, but nevertheless that was what happened. I had a goal this year to reach 26 mph, and I did just that . Not good enough for qualifying though ... 27 mph avg. needed for that, just crazy .Great fun going out in parts with patches of smooth tarmac and tailwind, getting nearly 30 mph for long sections. Drooling like a rabid drunk on the return leg with strong headwind struggling to keep above 20
I managed to do the danish Gran Fondo TT after all. Really cold, strong winds and a lot of tight turns. Normaly not the conditions for an all time best result, but nevertheless that was happened. I had a goal this year to reach 26 mph, and I did just that . Not good enough for qualifying though ... 27 mph avg. needed for that, just crazy .
Thanks .Great result Lars, i saw on Strava, very impressive with sharp bends to contend with- respect
Thanks .
Are you doing the Double Devil today?
