Thanks all. It does make me wonder why people go to the extra expense of measuring both sides independently then!
Because cyclists like giving their money away easily for STATS!!!
I confess to being surprised how interesting I am finding power data!Because cyclists like giving their money away easily for STATS!!!![]()
Good point!So they get a more accurate view of overall power. One sided pedals in your example would give a total power of 94 or 106 which is over 10%
A turbo trainer measures power on the axle. It wouldn't know which is left and which is right.Good point!
So, single-sided allows monitoring of progress, but double-sided would be better for accuracy.
Do smart turbo trainers tend to measure L, R, or L&R?
Tacx Neo trainers (and smart bikes) can measure left/right power I believe - not that I've ever looked at that data myself!
After Sundays 4hr epic ride for FRR stage 8 ,I woke on Monday morning with a very sore back did sitting on the turbo cause it ? Not 100% sure as I occasionally suffer from a bad back . So Monday was a complete rest day . Anyway overall results are in after stages and 10hrs 21min 58secs of racing I finished 36th of 55 riders who finished all 8 stages , 35mins 28secs down on Egap GC time ( I don't really understand Egap buts it's some way of balancing faster more well attended time slots ) . 35th /55 in the green Jersey and 32nd /55 in the Polka dot Jersey. It was a good series for me felt competitive in most stages and a best finish of 5th on a stage
You may be correct but the last tour I did the winner was decided on overall time ,this tour the guy in 11th overall is 5mins faster than the winner but has an Egap of 11mins but the winner has an Egap of zero suggesting he won every stage ?I thought eGap simply means if you win the race in your Cat you get 0s eGap and everyone else gets the number of seconds they were behind the winner of their race. The idea there being that if you had a very well populated heat it's only the relative times that count, rather than the absolute times. This makes it a bit fairer for comparing a heat of 10 riders against a heat of 40.
It struck me when I was out today that the Quarg IS measuring the output from both legs because the strain gauge is in the spider rather than the crank. It just doesn't know which leg is providing which peak in the power readings through the crank cycle.A turbo trainer measures power on the axle. It wouldn't know which is left and which is right.
My faulty 4iiii power meter was built onto one 105 crank so that would have only measured the output of my L leg. Doubling that would have exaggerated my power because my L leg does more work than my R.
I had to think about what you meant there...But unless you need the absolute numbers it would never affect anything.
If you were training based on FTP etc. it would be perfectly fine because the measurements are all relative.
