Zwift Chat
CXRAndy
CXRAndy
Lincs
Odd that the events have disappeared from ZP. It will come back
Whorty
Gets free watts from the Atom ;)
Wiltshire
I had a 'rest' day today, so climbed Alpe du zwift :tongue: knocked 7 minutes off my previous time :wahhey: HR was under control and I felt OK. Did it in just under 75 minutes. Chose the Fire to Ice course, which is the next ToW stage. Overall I took about 1 hour 46 mins. I can see quite a few people bailing on that course - will sort out people. Stage 4 and 5 come close on the tail so a tough 6 days!
bobinski
Tulse Hill
Well done. Great improvement.
I am looking forward to that stage. Not one to rush off on , at least for me, but one where hopefully get to pick people off as the road goes up.
bobinski
Tulse Hill
Most of have joined Zwift power club using cyclechat. Easier to spot results and if you add cyclechat to your Zwift user name we can see you easily whilst racing. Bob being the exception, hes different:tongue: easily spot name BOBBY-BABooska :laugh:
^_^
I am a proud member of Zsun especially considering they took me in as one of the original splitters:biggrin:
So, there as robert Dynowski
Ummh, must change it to Bob
Norry1
Warwick
Yep, I had already added Cyclechat to my name. Rob Taylor was fairly easy to find - but Kipster didn't appear on the list. Mr Kipster?? :smile:
Whorty
Wiltshire
I had a go last night as a rece. It's 25km in total, so with a main Alpe climb of 12.5 km there is a lot of riding before you get to the base of the mountain (including the climb up to the start of the jungle entrance). 1st part from the volcano is mostly flat or down, so I think i'll go out the blocks quite hard to get into a fastish group then sandbag to the first climb. Take my time up there then jump on another group through the jungle and sit on that at about 180 watts. Alpe itself I'll aim like last night to hold about 2.2-2.5 watts (so about 200 ish watts). In total, a course time around 1hr 40 i should think.
You climbers should be fine going off more slowly as you'll make up time on the mountain, but us lardies need to make a bit of time before the climb as I know i'll be dropped like a brick once I hit the steep sections.
Whorty
Wiltshire
As I rode 'Fire and Ice' last night so will have the whole ToW3 in Strava I'll create a segment that is mostly the course for the ToW3, then if you want we can use this for the times of that stage .... may not be 100% accurate distance as I might need to start a little later in the course and ending may not be on the KoM finish line so keep going when you get to the top for a few hundred metres to be sure. might work?
bridgy
Cheddar
There's a Strava segment already called "Tour of Fire & Ice (Zwift insider verified)" - https://www.strava.com/activities/1480172239/segments/36888524902 - which is pretty much the same distance etc. as stage 3, so may - hopefully - be completely included within stage 3 and we could use this? Maybe wait and see when someone's done the actual stage?
