alex_cycles
- Oxfordshire
I will be giving a couple of stages a go . Have registered but couldn't find a Cyclechat team so I'm in Ffr team can I change ?
Yes you should be able to go into your profile and edit that
I like it for the various time slots. I'm more a morning person![]()
Yup, click your profile and select the right team under Club Team. Looks like it's called 'CycleChat Riders'.I will be giving a couple of stages a go . Have registered but couldn't find a Cyclechat team so I'm in Ffr team can I change ?
Looking back I did 3 events. Tough racing equal to ZRL
Thanks everyone. I think I have correctly registered. It says @bridgy needs to verify I'm a fat chunt on the team page or something and I'm good to go. (Cheers bridgy) 👍
Not sure what I need to do Joffey (if anything?). You're showing on the team list so I assume all is good - I don't think I had to do anything to verify anyone else
Jalapeno - all explained here https://www.flammerougeracing.com/files/Rules/FRRTourRulesSeries2.pdfAh cool. Cheers for checking 👍
I'm a JLP - not sure what that is but it sounds like a boyband.
I was put off by the hilly courses ... so I'll stick to ZRL Tuesdays and if possible the odd Tiny race Saturdays. Depending on gym sessions, I'll maybe join a race on Thursdays but currently gym trumps cycling![]()
Full schedule is already up so plenty of time to plan![]()
It's not so much the courses that you need to check, but the distances. For example, the two 25km iTT's that are on the schedule both have custom finish points. Neither course is super hilly, but when you look at the distances you can work out that both are set up to have hilltop finishes on Box Hill (well one of them is actually Fox Hill cause it's coming from the other direction), which may make the decision for you.I will choose the flatter courses. I haven't looked what they're using. If there hilly, I'll give it a miss
